Other Parts Discussed in Thread: THS1206, SN74AHC138
Hey,
I want to operate several THS1207 in parallel, which will use only one databus to send their converted data. I plan to start the conversion process simultaneously, but i want to read the data in succession. It has to be read in succession, due to the shared databus. I want to achieve this by running each ADC with a separate Conv_Clk signal, which is stretched/interrupted at the right time. I want to make an example with 4 ADCs:
ADC A,B, C and D start the conversion at the same time. ADC A starts its dataoutput, while the others hold their data and wait until ADC A finishes his transmission. Then ADC B starts his data transmission, while the others wait and so on. When every ADC has transmitted its data, a new conversion cycle starts.
Does an implementation like this already exist? Is this implementation possible with the THS1207? If it is possible, how could an implementation look like?
My second question is, what the default values of the control registers 1 and 2 are. It is not described in the datasheet.
Thank you for your interest.
