What is the minimum amount of time required for the internal sampling capacitor to be discharged?
Hi John,
As Mr. Domanski noted in the original post, the internal sample cap does not automatically discharge in the ADC128S102 between samples. If you are having similar problems to those expressed by Mr. Song, you can follow the same advice provided in the original post. There are also a series of TI Precision Labs dedicated to ADC's which you might find useful. One in particular is SAR ADC Input Driver Design which goes through the basics of the sampling mechanism of a successive approximation register ADC.
Thanks for following up Ted. The hardware design is locked down so can't really make any changes there; however I can change the interface that drives the ADC. That's what prompted my question. When I read your response, it sounds like a qualitative thing. The ADC will produce better results if I give it more than the minimum 187.5ns acquisition (sounds like 2x is a good start). I think I was just looking for a spec on that. Anyway, thanks for all of your help.
John
