Other Parts Discussed in Thread: ADS5281, ADS5287
Hi All,
My customer is using ADS5281 in their system.
They implemented the python example file with TI software.
The problem is that ADS5281 has some error when selecting ADS device but there is no issue when selecting ADS5287.
I attached log files on both devices for you to check the error.
- could you let me know what caused this issue?
Sammy
D:\work>python "HSDCPro Automation DLL ADC Example.py" Connecting to board : K1226054-TSW1400 Error Status = 0 Selecting ADC Device : ADS5281 Error Status = 7005 Using HSDC Ready function to check if the GUI is Ready... Error Status = 0 Passing ADC Output Data Rate = 40000000 Error Status = 0 Starting normal capture.. Error Status = 0 Disconnecting from the board Error Status = 0 Importing data from CSV file at C:/HSDCPro Data/Testdata.csv Error Status = 7006 Importing data from Binary file at C:/HSDCPro Data/TestBinary.bin Error Status = 7006 Saving ADC Raw Data as CSV file at C:/HSDCPro Data/ADCdata.csv Error Status = 0 Saving ADC Raw Data as Binary file at C:/HSDCPro Data/ADCdata.bin Error Status = 0 Setting Additional Device Parameters.. Error Status = 0 Selecting Single Tone in ADC Test Selection.. Error Status = 0 Getting the Single Tone Parameter Values : SNR;SFDR;THD;SINAD;ENOB;Fund.;Next Sp ur;HD2;HD3;HD4;HD5;NSD/Hz Error Status = 0 The Parameter Values are: [46.97, 73.512, 71.973, 46.955, 7.507, -73.147, -73.512, -79.661, -78.841, -84.5 23, -85.689, -119.963] Selecting Two Tone in ADC Test Selection.. Error Status = 0 Setting Unit and Nyquist for Two Tone.. Error Status = 0 Getting the Two Tone Parameter Values : F1;F2;2F1+F2;2F2+F1;2F1-F2;2F2-F1;3F2-2F 1;3F1-2F2;F1+F2;F1-F2;3F1;3F2;2F1+2F2 Error Status = 0 The Parameter Values are: [610.352, 0.0, 610.352, 610.352, 610.352, 610.352, 610.352, 610.352, 610.352, 61 0.352, 610.352, 610.352, 610.352]
D:\work>python "HSDCPro Automation DLL ADC Example.py" Connecting to board : K1226054-TSW1400 Error Status = 0 Selecting ADC Device : ADS5287 Error Status = 0 Using HSDC Ready function to check if the GUI is Ready... Error Status = 0 Passing ADC Output Data Rate = 40000000 Error Status = 0 Starting normal capture.. Error Status = 0 Disconnecting from the board Error Status = 0 Importing data from CSV file at C:/HSDCPro Data/Testdata.csv Error Status = 7006 Importing data from Binary file at C:/HSDCPro Data/TestBinary.bin Error Status = 7006 Saving ADC Raw Data as CSV file at C:/HSDCPro Data/ADCdata.csv Error Status = 0 Saving ADC Raw Data as Binary file at C:/HSDCPro Data/ADCdata.bin Error Status = 0 Setting Additional Device Parameters.. Error Status = 0 Selecting Single Tone in ADC Test Selection.. Error Status = 0 Getting the Single Tone Parameter Values : SNR;SFDR;THD;SINAD;ENOB;Fund.;Next Sp ur;HD2;HD3;HD4;HD5;NSD/Hz Error Status = 0 The Parameter Values are: [57.572, 82.787, 75.328, 57.55, 9.267, -80.966, -84.684, -82.368, -86.209, -84.1 58, -88.81, -130.573] Selecting Two Tone in ADC Test Selection.. Error Status = 0 Setting Unit and Nyquist for Two Tone.. Error Status = 0 Getting the Two Tone Parameter Values : F1;F2;2F1+F2;2F2+F1;2F1-F2;2F2-F1;3F2-2F 1;3F1-2F2;F1+F2;F1-F2;3F1;3F2;2F1+2F2 Error Status = 0 The Parameter Values are: [610.352, 0.0, 610.352, 610.352, 610.352, 610.352, 610.352, 610.352, 610.352, 61 0.352, 610.352, 610.352, 610.352]
