We built a 4-Channel EEG measurement system that is based on ADS1299. We have been experimenting on different Register Configurations settings and we obtained some results. We are quite sure how good or bad the signal quality is.
We have two questions. One Informative and the other is a technical question.
Question 1 (Informative): Can someone recommend us a company or freelancer in Germany (or around) who is an expert in ADS1299 and can offer professional EEG Signal QUALITY consultancy. (Sorry if this is not the right place to ask such questions).
Question (Technical) :
After we received the 24 bit hexadecimal output of ADS1299, we converted it into decimal numbers using this formula from the document :
voltage = code * Vref / [PGA gain * (2^23-1)
The configure our gain to be 24. We used Vref =4.5. The question is when can we use Vref=2.5?
Secondly, below is part of the raw EEG signal we obtained using the above formula. Is this EEG signal or just some noisy artifacts?
Lastly, how can we compute Alpha, Beta, Theta, Delta waves from this signal? We should note that we are not using the Open BCI board.
Signal from some electrodes (First 20 sample point):
Sampling Frequency: 250 Hz
Electrode1:
0.115835568706461,-0.0646460282380615,-0.0448426955750818,0.0516473488983332,-0.0638967307086862,-0.0584033648256498,-0.0778067353733463,-0.186205901051271,-0.156537871842131,0.120433277837429,-0.0892165856619579,-0.0571902015435936,0.0648374485775767,-0.0766924338570158,-0.100786765013548,-0.0199855440837793,0.0908620540335243,0.0689515777172539,0.0248223945286744,0.173917224874166 ....
Electrode 2:
0.0762122736826269,-0.0335254709154929,0.167718862619264,-0.061558537072961,0.13287088368784,-0.0769389512466134,0.151050585633586,0.0839137684004031,-0.130509198368692,-0.17473489638983,0.0846802544212645,-0.185863517029705,-0.118497907340277,0.1316463657196,-0.0414169331093947,0.0706212083245764,0.111499799668765,0.033622678652129,0.0495750516146483,0.061116419567635
We are quite sure how good or bad the signal quality is. == We are NOT quite sure how good or bad the signal quality is.
Welcome to our forum and thank you for your post!
Unfortunately, we do not have a recommendation for EEG consultation.
Regarding your other questions:
Dear Ryan,
Thanks for your reply. In my question, I presented the outputted raw EEG signal results of two Electrodes in Volt.
Are these real EEG signal or some noise artifacts?
Thanks & Best Regards.
Hello - as I said in my previous reply, we do not have the medical expertise to identify those signals as EEG or noise.
