Part Number: DAC81416
Other Parts Discussed in Thread: TPS65131
I want to use the full output swing of +/-20V from DAC81416. I have found an IC
TPS65131 but this is only between +/-15V. Is there a chip similar to this that can
provide a higher output range? Or is there an appnote power design solution to
provide +/-20V for DAC81416. I'm looking for a solution that can provide around
a watt with +/-20 for Vss and Vcc of the 81416. Thank you so much.
