Other Parts Discussed in Thread: TMDXEVMPCI
Is TI's EVMK2H Evaluation board electrically and mechanically compatable with the TMDXEVMPCI AMC to PCIe Adapter card?
No. The TMDXEVMPCI is only compatible with KeyStone I EVMs.
The only other option I know is breakout cards connected with SMA cables. You can use an AMC SMA breakout card such as the AMC SMA ULTRA 9000 connected to the PCIE connector with a PCIE adapter cable. This would allow the PCIE interface of the K2H EVM to be connected to a system with a PCIE connector. Remember that you will need to include the 100MHz reference clock in your connections if your target system operates with a spread spectrum clock.
Regards, Bill
