We are using Sharp 7" LCD (LQ070Y3DG1A) for OMAP3503 board. I need some inputs on
how to configure the contrast ratio. Anyone had worked on this, else have any idea
on how this will impact the driver?
Thanks & Regards,
-Subash
Thanks & Regards,
-Subash
Did you check the V4L2 ioctl support for changing contrast, brightness, saturation etc. There is a set control V4L2 ioctl which you can call with the required control id(say contrast or saturation etc) to change the display parameters.
Prathap.
