Unstable bitrate while changing bitrate dynamically
Hello TI,
We are using DM8148 based custom board and using ezsdk_dm814x-evm_5_05_01_04 from software perspective.
In one of our application it is required to change bit-rate dynamically which we achieve successfully, but when we change bitrate dynamically, bit-rate is not stable. For example, we set initial target bitrate to 200 kbps and the actual corresponding bitrate is accurate (equal to 205-210 kbps). However, after switching target bitrate to 600 kbps the actual encoder output bit-rate is approximately 450 kbps.
we attached video sample here with the 600 kbps bitrate after 100 frames of video for your reference.
8156.7181.sample.rar
Please suggest.
Devang
