The examples in the documentation do not match the schemas. For example, on the website
https://api-portal.ti.com/store-order-api#/TI%20store%20production%20order/post_store_orders
https://api-portal.ti.com/store-order-api#/TI%20store%20test%20order/post_store_orders_test
In the example is "customerItemComments" inside "lineItems".
In the schema is "customerItemComments" next to the same level as "lineItems".
In the example is "lineItems" but in the schema is only "numberOfLineItems" without detail about items
Can you check all the schema sections in the documentation for more inaccuracies?
Hi Petr,
Thanks for sharing your findings. We'll check these out and make needed corrections within the next week.
Thanks and best regards,
Paul
Petr,
Sorry for the delay. I updated the schema so the the customer line item comments are within the line item objects, aligning with the examples that were correct. Only customer order comments is at the top level of an order.
What you are seeing with respect to numberOfLineItems is the schema for the GET /store/orders summary response. The summary contains an array of all orders placed within a timeframe, but does not contain all of the line item details for each order. The GET /store/orders/{orderNumber} request will provide the details, and I see that the schema for the order details response is missing from the spec. I'll leave this issue open until we can update it.
Thanks again,
Paul
