We have a credit limit of $5000 per month.
- What happens if we place an order via API, an order which is totaling over $5000 within that month?
- Will the order placement proceed?
- If the order will be cancelled, does the API return any error message? (What does the API return?)
Hi tomonarifujii,
Are you speaking of an Apruve line of credit and the TI store order API?
Paul
No, I mean TI line of credit.
As for the API, yes, I mean the TI store order API is what I'm referring to.
If there is any other API that behaves differently when you have insufficient credit, it would be appreciated if you could tell me which API.
Tomonari
Hi tomonarifujii,
If the order total exceeds the available credit limit, the order should be rejected with a message to check your credit account information. Have you experienced something differently?
Paul
Thank you for the information.
No I haven't experienced any because we are just testing our system on the testing environment only, which I assume cannot influenced by credit limit.
Correct, for test orders the only check is that the payment method is properly setup, but not any checks on the account itself.
Paul
Hi Paul King,
Thank you for your previous response regarding the behavior of the TI store order API when the order total exceeds the available credit limit. You mentioned that the order "should be" rejected with a message to check the credit account information.
To ensure clarity and avoid any potential misunderstandings, could you please confirm the following:
Your confirmation on these points will be greatly appreciated as we aim to integrate this behavior accurately into our system.
Thank you in advance for your assistance.
Tomonari
Hi tomonarifujii,
I tested to verify that the following error is returned when an order total exceeds the available credit for a checkout profile that is linked to an Apruve line of credit (as your completed checkout profile is):
"errors": [ { "errorCode": "ERR-TICOM-ORDER-API-0009", "type": "Validation", "section": "Generic", "field": null, "reason": "Invalid Apruve payment Id", "message": "Check your Apruve Account information in checkout profile and resubmit your request. For additional information refer to https://api-portal.ti.com/order-api-payment", "data": null } ]
Paul
Hi tomonarifujii,
For the same scenario with a TI line of credit, you would receive the following error response:
"errors": [ { "errorCode": "ERR-TICOM-ORDER-API-0009", "type": "Validation", "section": "Generic", "field": null, "reason": "Insufficient Credit Limit", "message": "Your cart total exceeds your available credit. Edit cart to bring it below the available credit or choose another payment option.", "data": null } ]
Paul
