Registry change for XIO2000
Other Parts Discussed in Thread: XIO2001
 ・PCIe 1.0a Device Prevent Resume from S1
 http://focus.tij.co.jp/jp/lit/an/scpa040/scpa040.pdf
Please tell me whether the registry change introduced with above-mentioned URL is applicable in the following OS or not?
■OS : Windows7 64Bit version
    Yes, you need to  implement the register change.
    The error occurs because of the standard architecture PCIe Base 1.0a, so no matter what OS you are using.
    The XIO2000 is an old device with some known erratas, may I suggest the XIO2001 wich is the improved version of the XIO2000.
    Regards.
  • Hi ELIAS,
    Thanks for your answer.
    I will implement the register change.
    Because the compatible pin of XIO2000 and XIO2001 doesn't exist, either it is not easy to regenerate an existing system.
    But,If  it is a problem of XIO2000, it thinks about the replacement with XIO2001.
