Part Number: TMDS181
Hello expert,
My customer has question for TMDS181.
This device has 2 type of configuration method that one is pin strap and the other is I2C.
In datasheet, I2C overwrite the pin strap configuration when I2C is enable.
Then could we remain all input pin regarding configuration as NC? Or should we connect register for maintain particular voltage?
This question is from we worried about configuration is changed by PIN even if I2C is enabled. Because datasheet only said setting is "overwrote" by I2C so I suspect can change setting by pin if setting haven't be changed by I2C.
Kazuki Kuramochi
