DS90UB947-Q1: DS90UB947-Q1 only port 0 have output but port 1 no
Part Number: DS90UB947-Q1
Hi team,
customer use 947+948, set 947 into force dual mode, and 948 is auto detect. but found only Port 0 of 947 have output, and 948 side display abnoraml.
read 0x28 of 948 is 0x21, work in single mode,
read 0x5A of 947 is 0x1D, work in single mode,
read 0x5B of 947 is 0x03, work in  force dual mode
the 0x5A is conflict with 0x5B.
could you help check it and give suggestions? I attached the schematic and error 947/948 register value, thank you.
# config_ds9478_S106.sh 1
ds9478 [mode]
mode:
 1: read all register ds947/ds948
 2: Enable PATGEN with color bars and external timing on 947
 3: Reset FPD PLL
 4: Reset OLDI PLL
 5: Reset OLDI block
 6: Rest ds947
 7: Set external clock internal PATGEN timing.(1920*720)
 8: Set internal clock internal PATGEN timing.(1920*720)
 9: 	Set external clock internal PATGEN timing.(1920*1080)
 10: Set internal clock internal PATGEN timing.(1920*1080)
 11: Set external clock internal PATGEN timing.(960*1280)
 12: Set internal clock internal PATGEN timing.(960*1280)
 13: Set external clock internal PATGEN timing.(1920*1200)
 14: Set internal clock internal PATGEN timing.(1920*1200)
 15: Enable PATGEN with color bars and external timing on 948
 16: DisEnable PATGEN with color bars and external timing on 948
 17: DisEnable PATGEN with color bars and external timing on 947
 start read  ds947/ds948 register
start read ds947 register
Read i2c bus:8,device:0x0C address:0x00,value:0x18
Read i2c bus:8,device:0x0C address:0x01,value:0x80
Read i2c bus:8,device:0x0C address:0x02,value:0x00
Read i2c bus:8,device:0x0C address:0x03,value:0xDA
Read i2c bus:8,device:0x0C address:0x04,value:0x90
Read i2c bus:8,device:0x0C address:0x05,value:0x00
Read i2c bus:8,device:0x0C address:0x06,value:0x58
Read i2c bus:8,device:0x0C address:0x07,value:0x00
Read i2c bus:8,device:0x0C address:0x08,value:0x00
Read i2c bus:8,device:0x0C address:0x09,value:0x00
Read i2c bus:8,device:0x0C address:0x0A,value:0x11
Read i2c bus:8,device:0x0C address:0x0B,value:0x00
Read i2c bus:8,device:0x0C address:0x0C,value:0x07
Read i2c bus:8,device:0x0C address:0x0D,value:0x23
Read i2c bus:8,device:0x0C address:0x0E,value:0x03
Read i2c bus:8,device:0x0C address:0x0F,value:0x05
Read i2c bus:8,device:0x0C address:0x10,value:0x00
Read i2c bus:8,device:0x0C address:0x11,value:0x00
Read i2c bus:8,device:0x0C address:0x12,value:0x00
Read i2c bus:8,device:0x0C address:0x13,value:0x8F
Read i2c bus:8,device:0x0C address:0x14,value:0x00
Read i2c bus:8,device:0x0C address:0x15,value:0x00
Read i2c bus:8,device:0x0C address:0x16,value:0x02
Read i2c bus:8,device:0x0C address:0x17,value:0xDE
Read i2c bus:8,device:0x0C address:0x18,value:0x7F
Read i2c bus:8,device:0x0C address:0x19,value:0x7F
Read i2c bus:8,device:0x0C address:0x1A,value:0x01
Read i2c bus:8,device:0x0C address:0x1B,value:0x00
Read i2c bus:8,device:0x0C address:0x1C,value:0x25
Read i2c bus:8,device:0x0C address:0x1D,value:0x00
Read i2c bus:8,device:0x0C address:0x1E,value:0x01
Read i2c bus:8,device:0x0C address:0x1F,value:0x00
Read i2c bus:8,device:0x0C address:0x20,value:0x0B
Read i2c bus:8,device:0x0C address:0x21,value:0x00
Read i2c bus:8,device:0x0C address:0x22,value:0x25
Read i2c bus:8,device:0x0C address:0x23,value:0x00
Read i2c bus:8,device:0x0C address:0x24,value:0x00
Read i2c bus:8,device:0x0C address:0x25,value:0x00
Read i2c bus:8,device:0x0C address:0x26,value:0x00
Read i2c bus:8,device:0x0C address:0x27,value:0x00
Read i2c bus:8,device:0x0C address:0x28,value:0x01
Read i2c bus:8,device:0x0C address:0x29,value:0x20
Read i2c bus:8,device:0x0C address:0x2A,value:0x20
Read i2c bus:8,device:0x0C address:0x2B,value:0xB8
Read i2c bus:8,device:0x0C address:0x2C,value:0x00
Read i2c bus:8,device:0x0C address:0x2D,value:0x00
Read i2c bus:8,device:0x0C address:0x2E,value:0xA5
Read i2c bus:8,device:0x0C address:0x2F,value:0x5A
Read i2c bus:8,device:0x0C address:0x30,value:0x00
Read i2c bus:8,device:0x0C address:0x31,value:0x00
Read i2c bus:8,device:0x0C address:0x32,value:0x00
Read i2c bus:8,device:0x0C address:0x33,value:0x00
Read i2c bus:8,device:0x0C address:0x34,value:0x00
Read i2c bus:8,device:0x0C address:0x35,value:0x00
Read i2c bus:8,device:0x0C address:0x36,value:0x00
Read i2c bus:8,device:0x0C address:0x37,value:0x00
Read i2c bus:8,device:0x0C address:0x38,value:0x00
Read i2c bus:8,device:0x0C address:0x39,value:0x00
Read i2c bus:8,device:0x0C address:0x3A,value:0x00
Read i2c bus:8,device:0x0C address:0x3B,value:0x00
Read i2c bus:8,device:0x0C address:0x3C,value:0x00
Read i2c bus:8,device:0x0C address:0x3D,value:0x00
Read i2c bus:8,device:0x0C address:0x3E,value:0x00
Read i2c bus:8,device:0x0C address:0x3F,value:0x00
Read i2c bus:8,device:0x0C address:0x40,value:0x10
Read i2c bus:8,device:0x0C address:0x41,value:0x49
Read i2c bus:8,device:0x0C address:0x42,value:0x00
Read i2c bus:8,device:0x0C address:0x43,value:0x00
Read i2c bus:8,device:0x0C address:0x44,value:0x80
Read i2c bus:8,device:0x0C address:0x45,value:0x00
Read i2c bus:8,device:0x0C address:0x46,value:0x63
Read i2c bus:8,device:0x0C address:0x47,value:0x00
Read i2c bus:8,device:0x0C address:0x48,value:0x00
Read i2c bus:8,device:0x0C address:0x49,value:0x00
Read i2c bus:8,device:0x0C address:0x4A,value:0x00
Read i2c bus:8,device:0x0C address:0x4B,value:0x00
Read i2c bus:8,device:0x0C address:0x4C,value:0x00
Read i2c bus:8,device:0x0C address:0x4D,value:0x00
Read i2c bus:8,device:0x0C address:0x4E,value:0x00
Read i2c bus:8,device:0x0C address:0x4F,value:0x40
Read i2c bus:8,device:0x0C address:0x50,value:0x16
Read i2c bus:8,device:0x0C address:0x51,value:0x00
Read i2c bus:8,device:0x0C address:0x52,value:0x00
Read i2c bus:8,device:0x0C address:0x53,value:0x00
Read i2c bus:8,device:0x0C address:0x54,value:0x02
Read i2c bus:8,device:0x0C address:0x55,value:0x00
Read i2c bus:8,device:0x0C address:0x56,value:0x00
Read i2c bus:8,device:0x0C address:0x57,value:0x02
Read i2c bus:8,device:0x0C address:0x58,value:0x00
Read i2c bus:8,device:0x0C address:0x59,value:0x00
Read i2c bus:8,device:0x0C address:0x5A,value:0x1D
Read i2c bus:8,device:0x0C address:0x5B,value:0x03
Read i2c bus:8,device:0x0C address:0x5C,value:0x02
Read i2c bus:8,device:0x0C address:0x5D,value:0x06
Read i2c bus:8,device:0x0C address:0x5E,value:0x44
Read i2c bus:8,device:0x0C address:0x5F,value:0xA0
Read i2c bus:8,device:0x0C address:0x60,value:0x22
Read i2c bus:8,device:0x0C address:0x61,value:0x02
Read i2c bus:8,device:0x0C address:0x62,value:0x00
Read i2c bus:8,device:0x0C address:0x63,value:0x00
Read i2c bus:8,device:0x0C address:0x64,value:0x00
Read i2c bus:8,device:0x0C address:0x65,value:0x00
Read i2c bus:8,device:0x0C address:0x66,value:0x00
Read i2c bus:8,device:0x0C address:0x67,value:0x00
Read i2c bus:8,device:0x0C address:0x68,value:0x00
Read i2c bus:8,device:0x0C address:0x69,value:0x00
Read i2c bus:8,device:0x0C address:0x6A,value:0x00
Read i2c bus:8,device:0x0C address:0x6B,value:0x00
Read i2c bus:8,device:0x0C address:0x6C,value:0x00
Read i2c bus:8,device:0x0C address:0x6D,value:0x00
Read i2c bus:8,device:0x0C address:0x6E,value:0x00
Read i2c bus:8,device:0x0C address:0x6F,value:0x00
Read i2c bus:8,device:0x0C address:0x70,value:0x00
Read i2c bus:8,device:0x0C address:0x71,value:0x00
Read i2c bus:8,device:0x0C address:0x72,value:0x00
Read i2c bus:8,device:0x0C address:0x73,value:0x00
Read i2c bus:8,device:0x0C address:0x74,value:0x00
Read i2c bus:8,device:0x0C address:0x75,value:0x00
Read i2c bus:8,device:0x0C address:0x76,value:0x00
Read i2c bus:8,device:0x0C address:0x77,value:0x00
Read i2c bus:8,device:0x0C address:0x78,value:0x00
Read i2c bus:8,device:0x0C address:0x79,value:0x00
Read i2c bus:8,device:0x0C address:0x7A,value:0x00
Read i2c bus:8,device:0x0C address:0x7B,value:0x00
Read i2c bus:8,device:0x0C address:0x7C,value:0x00
Read i2c bus:8,device:0x0C address:0x7D,value:0x00
Read i2c bus:8,device:0x0C address:0x7E,value:0x00
Read i2c bus:8,device:0x0C address:0x7F,value:0x00
Read i2c bus:8,device:0x0C address:0x80,value:0x00
Read i2c bus:8,device:0x0C address:0x81,value:0x00
Read i2c bus:8,device:0x0C address:0x82,value:0x00
Read i2c bus:8,device:0x0C address:0x83,value:0x00
Read i2c bus:8,device:0x0C address:0x84,value:0x00
Read i2c bus:8,device:0x0C address:0x85,value:0x00
Read i2c bus:8,device:0x0C address:0x86,value:0x00
Read i2c bus:8,device:0x0C address:0x87,value:0x00
Read i2c bus:8,device:0x0C address:0x88,value:0x00
Read i2c bus:8,device:0x0C address:0x89,value:0x00
Read i2c bus:8,device:0x0C address:0x8A,value:0x00
Read i2c bus:8,device:0x0C address:0x8B,value:0x00
Read i2c bus:8,device:0x0C address:0x8C,value:0x00
Read i2c bus:8,device:0x0C address:0x8D,value:0x00
Read i2c bus:8,device:0x0C address:0x8E,value:0x00
Read i2c bus:8,device:0x0C address:0x8F,value:0x00
Read i2c bus:8,device:0x0C address:0x90,value:0x00
Read i2c bus:8,device:0x0C address:0x91,value:0x00
Read i2c bus:8,device:0x0C address:0x92,value:0x00
Read i2c bus:8,device:0x0C address:0x93,value:0x00
Read i2c bus:8,device:0x0C address:0x94,value:0x00
Read i2c bus:8,device:0x0C address:0x95,value:0x00
Read i2c bus:8,device:0x0C address:0x96,value:0x00
Read i2c bus:8,device:0x0C address:0x97,value:0x00
Read i2c bus:8,device:0x0C address:0x98,value:0x00
Read i2c bus:8,device:0x0C address:0x99,value:0x00
Read i2c bus:8,device:0x0C address:0x9A,value:0x00
Read i2c bus:8,device:0x0C address:0x9B,value:0x00
Read i2c bus:8,device:0x0C address:0x9C,value:0x00
Read i2c bus:8,device:0x0C address:0x9D,value:0x00
Read i2c bus:8,device:0x0C address:0x9E,value:0x00
Read i2c bus:8,device:0x0C address:0x9F,value:0x00
Read i2c bus:8,device:0x0C address:0xA0,value:0x00
Read i2c bus:8,device:0x0C address:0xA1,value:0x00
Read i2c bus:8,device:0x0C address:0xA2,value:0x00
Read i2c bus:8,device:0x0C address:0xA3,value:0x00
Read i2c bus:8,device:0x0C address:0xA4,value:0x00
Read i2c bus:8,device:0x0C address:0xA5,value:0x00
Read i2c bus:8,device:0x0C address:0xA6,value:0x00
Read i2c bus:8,device:0x0C address:0xA7,value:0x00
Read i2c bus:8,device:0x0C address:0xA8,value:0x00
Read i2c bus:8,device:0x0C address:0xA9,value:0x00
Read i2c bus:8,device:0x0C address:0xAA,value:0x00
Read i2c bus:8,device:0x0C address:0xAB,value:0x00
Read i2c bus:8,device:0x0C address:0xAC,value:0x00
Read i2c bus:8,device:0x0C address:0xAD,value:0x00
Read i2c bus:8,device:0x0C address:0xAE,value:0x00
Read i2c bus:8,device:0x0C address:0xAF,value:0x00
Read i2c bus:8,device:0x0C address:0xB0,value:0x00
Read i2c bus:8,device:0x0C address:0xB1,value:0x00
Read i2c bus:8,device:0x0C address:0xB2,value:0x00
Read i2c bus:8,device:0x0C address:0xB3,value:0x00
Read i2c bus:8,device:0x0C address:0xB4,value:0x00
Read i2c bus:8,device:0x0C address:0xB5,value:0x00
Read i2c bus:8,device:0x0C address:0xB6,value:0x00
Read i2c bus:8,device:0x0C address:0xB7,value:0x00
Read i2c bus:8,device:0x0C address:0xB8,value:0x00
Read i2c bus:8,device:0x0C address:0xB9,value:0x00
Read i2c bus:8,device:0x0C address:0xBA,value:0x00
Read i2c bus:8,device:0x0C address:0xBB,value:0x00
Read i2c bus:8,device:0x0C address:0xBC,value:0x00
Read i2c bus:8,device:0x0C address:0xBD,value:0x00
Read i2c bus:8,device:0x0C address:0xBE,value:0x00
Read i2c bus:8,device:0x0C address:0xBF,value:0x00
Read i2c bus:8,device:0x0C address:0xC0,value:0x00
Read i2c bus:8,device:0x0C address:0xC1,value:0x00
Read i2c bus:8,device:0x0C address:0xC2,value:0xB8
Read i2c bus:8,device:0x0C address:0xC3,value:0x00
Read i2c bus:8,device:0x0C address:0xC4,value:0x78
Read i2c bus:8,device:0x0C address:0xC5,value:0x00
Read i2c bus:8,device:0x0C address:0xC6,value:0x00
Read i2c bus:8,device:0x0C address:0xC7,value:0x60
Read i2c bus:8,device:0x0C address:0xC8,value:0xC0
Read i2c bus:8,device:0x0C address:0xC9,value:0x00
Read i2c bus:8,device:0x0C address:0xCA,value:0x00
Read i2c bus:8,device:0x0C address:0xCB,value:0x00
Read i2c bus:8,device:0x0C address:0xCC,value:0x00
Read i2c bus:8,device:0x0C address:0xCD,value:0x00
Read i2c bus:8,device:0x0C address:0xCE,value:0xFF
Read i2c bus:8,device:0x0C address:0xCF,value:0x00
Read i2c bus:8,device:0x0C address:0xD0,value:0x00
Read i2c bus:8,device:0x0C address:0xD1,value:0x00
Read i2c bus:8,device:0x0C address:0xD2,value:0x00
Read i2c bus:8,device:0x0C address:0xD3,value:0x00
Read i2c bus:8,device:0x0C address:0xD4,value:0x00
Read i2c bus:8,device:0x0C address:0xD5,value:0x00
Read i2c bus:8,device:0x0C address:0xD6,value:0x00
Read i2c bus:8,device:0x0C address:0xD7,value:0x00
Read i2c bus:8,device:0x0C address:0xD8,value:0x00
Read i2c bus:8,device:0x0C address:0xD9,value:0x00
Read i2c bus:8,device:0x0C address:0xDA,value:0x00
Read i2c bus:8,device:0x0C address:0xDB,value:0x00
Read i2c bus:8,device:0x0C address:0xDC,value:0x00
Read i2c bus:8,device:0x0C address:0xDD,value:0x00
Read i2c bus:8,device:0x0C address:0xDE,value:0x00
Read i2c bus:8,device:0x0C address:0xDF,value:0x00
Read i2c bus:8,device:0x0C address:0xE0,value:0x00
Read i2c bus:8,device:0x0C address:0xE1,value:0x00
Read i2c bus:8,device:0x0C address:0xE2,value:0xB8
Read i2c bus:8,device:0x0C address:0xE3,value:0x00
Read i2c bus:8,device:0x0C address:0xE4,value:0x68
Read i2c bus:8,device:0x0C address:0xE5,value:0x38
Read i2c bus:8,device:0x0C address:0xE6,value:0x00
Read i2c bus:8,device:0x0C address:0xE7,value:0x00
Read i2c bus:8,device:0x0C address:0xE8,value:0x00
Read i2c bus:8,device:0x0C address:0xE9,value:0x00
Read i2c bus:8,device:0x0C address:0xEA,value:0x00
Read i2c bus:8,device:0x0C address:0xEB,value:0x00
Read i2c bus:8,device:0x0C address:0xEC,value:0x00
Read i2c bus:8,device:0x0C address:0xED,value:0x00
Read i2c bus:8,device:0x0C address:0xEE,value:0x00
Read i2c bus:8,device:0x0C address:0xEF,value:0x00
Read i2c bus:8,device:0x0C address:0xF0,value:0x5F
Read i2c bus:8,device:0x0C address:0xF1,value:0x55
Read i2c bus:8,device:0x0C address:0xF2,value:0x42
Read i2c bus:8,device:0x0C address:0xF3,value:0x39
Read i2c bus:8,device:0x0C address:0xF4,value:0x34
Read i2c bus:8,device:0x0C address:0xF5,value:0x37
Read i2c bus:8,device:0x0C address:0xF6,value:0x00
Read i2c bus:8,device:0x0C address:0xF7,value:0x00
Read i2c bus:8,device:0x0C address:0xF8,value:0x00
Read i2c bus:8,device:0x0C address:0xF9,value:0x00
Read i2c bus:8,device:0x0C address:0xFA,value:0x00
Read i2c bus:8,device:0x0C address:0xFB,value:0x00
Read i2c bus:8,device:0x0C address:0xFC,value:0x00
Read i2c bus:8,device:0x0C address:0xFD,value:0x00
Read i2c bus:8,device:0x0C address:0xFE,value:0x00
start read ds948 register
Read i2c bus:8,device:0x2C address:0x00,value:0x58
Read i2c bus:8,device:0x2C address:0x01,value:0x04
Read i2c bus:8,device:0x2C address:0x02,value:0x00
Read i2c bus:8,device:0x2C address:0x03,value:0xF0
Read i2c bus:8,device:0x2C address:0x04,value:0xFE
Read i2c bus:8,device:0x2C address:0x05,value:0x1E
Read i2c bus:8,device:0x2C address:0x06,value:0x00
Read i2c bus:8,device:0x2C address:0x07,value:0x18
Read i2c bus:8,device:0x2C address:0x08,value:0x00
Read i2c bus:8,device:0x2C address:0x09,value:0x00
Read i2c bus:8,device:0x2C address:0x0A,value:0x00
Read i2c bus:8,device:0x2C address:0x0B,value:0x00
Read i2c bus:8,device:0x2C address:0x0C,value:0x00
Read i2c bus:8,device:0x2C address:0x0D,value:0x00
Read i2c bus:8,device:0x2C address:0x0E,value:0x00
Read i2c bus:8,device:0x2C address:0x0F,value:0x00
Read i2c bus:8,device:0x2C address:0x10,value:0x00
Read i2c bus:8,device:0x2C address:0x11,value:0x00
Read i2c bus:8,device:0x2C address:0x12,value:0x00
Read i2c bus:8,device:0x2C address:0x13,value:0x00
Read i2c bus:8,device:0x2C address:0x14,value:0x00
Read i2c bus:8,device:0x2C address:0x15,value:0x00
Read i2c bus:8,device:0x2C address:0x16,value:0x00
Read i2c bus:8,device:0x2C address:0x17,value:0x00
Read i2c bus:8,device:0x2C address:0x18,value:0x00
Read i2c bus:8,device:0x2C address:0x19,value:0x01
Read i2c bus:8,device:0x2C address:0x1A,value:0x00
Read i2c bus:8,device:0x2C address:0x1B,value:0x00
Read i2c bus:8,device:0x2C address:0x1C,value:0x22
Read i2c bus:8,device:0x2C address:0x1D,value:0x15
Read i2c bus:8,device:0x2C address:0x1E,value:0x05
Read i2c bus:8,device:0x2C address:0x1F,value:0x03
Read i2c bus:8,device:0x2C address:0x20,value:0x90
Read i2c bus:8,device:0x2C address:0x21,value:0x99
Read i2c bus:8,device:0x2C address:0x22,value:0x00
Read i2c bus:8,device:0x2C address:0x23,value:0x30
Read i2c bus:8,device:0x2C address:0x24,value:0x08
Read i2c bus:8,device:0x2C address:0x25,value:0x00
Read i2c bus:8,device:0x2C address:0x26,value:0x83
Read i2c bus:8,device:0x2C address:0x27,value:0x84
Read i2c bus:8,device:0x2C address:0x28,value:0x21
Read i2c bus:8,device:0x2C address:0x29,value:0x00
Read i2c bus:8,device:0x2C address:0x2A,value:0x00
Read i2c bus:8,device:0x2C address:0x2B,value:0x00
Read i2c bus:8,device:0x2C address:0x2C,value:0x00
Read i2c bus:8,device:0x2C address:0x2D,value:0x00
Read i2c bus:8,device:0x2C address:0x2E,value:0x00
Read i2c bus:8,device:0x2C address:0x2F,value:0x00
Read i2c bus:8,device:0x2C address:0x30,value:0x72
Read i2c bus:8,device:0x2C address:0x31,value:0x00
Read i2c bus:8,device:0x2C address:0x32,value:0x90
Read i2c bus:8,device:0x2C address:0x33,value:0x25
Read i2c bus:8,device:0x2C address:0x34,value:0x01
Read i2c bus:8,device:0x2C address:0x35,value:0x00
Read i2c bus:8,device:0x2C address:0x36,value:0x00
Read i2c bus:8,device:0x2C address:0x37,value:0xA8
Read i2c bus:8,device:0x2C address:0x38,value:0x00
Read i2c bus:8,device:0x2C address:0x39,value:0x00
Read i2c bus:8,device:0x2C address:0x3A,value:0x00
Read i2c bus:8,device:0x2C address:0x3B,value:0x00
Read i2c bus:8,device:0x2C address:0x3C,value:0x20
Read i2c bus:8,device:0x2C address:0x3D,value:0xE0
Read i2c bus:8,device:0x2C address:0x3E,value:0x23
Read i2c bus:8,device:0x2C address:0x3F,value:0x00
Read i2c bus:8,device:0x2C address:0x40,value:0x43
Read i2c bus:8,device:0x2C address:0x41,value:0x1F
Read i2c bus:8,device:0x2C address:0x42,value:0x03
Read i2c bus:8,device:0x2C address:0x43,value:0x00
Read i2c bus:8,device:0x2C address:0x44,value:0x01
Read i2c bus:8,device:0x2C address:0x45,value:0x88
Read i2c bus:8,device:0x2C address:0x46,value:0x00
Read i2c bus:8,device:0x2C address:0x47,value:0x00
Read i2c bus:8,device:0x2C address:0x48,value:0x0F
Read i2c bus:8,device:0x2C address:0x49,value:0x41
Read i2c bus:8,device:0x2C address:0x4A,value:0x00
Read i2c bus:8,device:0x2C address:0x4B,value:0x08
Read i2c bus:8,device:0x2C address:0x4C,value:0x00
Read i2c bus:8,device:0x2C address:0x4D,value:0x00
Read i2c bus:8,device:0x2C address:0x4E,value:0x63
Read i2c bus:8,device:0x2C address:0x4F,value:0x00
Read i2c bus:8,device:0x2C address:0x50,value:0x03
Read i2c bus:8,device:0x2C address:0x51,value:0x10
Read i2c bus:8,device:0x2C address:0x52,value:0x00
Read i2c bus:8,device:0x2C address:0x53,value:0x01
Read i2c bus:8,device:0x2C address:0x54,value:0x80
Read i2c bus:8,device:0x2C address:0x55,value:0x00
Read i2c bus:8,device:0x2C address:0x56,value:0x00
Read i2c bus:8,device:0x2C address:0x57,value:0x00
Read i2c bus:8,device:0x2C address:0x58,value:0x00
Read i2c bus:8,device:0x2C address:0x59,value:0x7F
Read i2c bus:8,device:0x2C address:0x5A,value:0x20
Read i2c bus:8,device:0x2C address:0x5B,value:0x20
Read i2c bus:8,device:0x2C address:0x5C,value:0x00
Read i2c bus:8,device:0x2C address:0x5D,value:0x00
Read i2c bus:8,device:0x2C address:0x5E,value:0x00
Read i2c bus:8,device:0x2C address:0x5F,value:0x00
Read i2c bus:8,device:0x2C address:0x60,value:0x00
Read i2c bus:8,device:0x2C address:0x61,value:0x00
Read i2c bus:8,device:0x2C address:0x62,value:0x00
Read i2c bus:8,device:0x2C address:0x63,value:0x00
Read i2c bus:8,device:0x2C address:0x64,value:0x04
Read i2c bus:8,device:0x2C address:0x65,value:0x00
Read i2c bus:8,device:0x2C address:0x66,value:0x19
Read i2c bus:8,device:0x2C address:0x67,value:0x00
Read i2c bus:8,device:0x2C address:0x68,value:0x00
Read i2c bus:8,device:0x2C address:0x69,value:0x00
Read i2c bus:8,device:0x2C address:0x6A,value:0x00
Read i2c bus:8,device:0x2C address:0x6B,value:0x00
Read i2c bus:8,device:0x2C address:0x6C,value:0x00
Read i2c bus:8,device:0x2C address:0x6D,value:0x00
Read i2c bus:8,device:0x2C address:0x6E,value:0x00
Read i2c bus:8,device:0x2C address:0x6F,value:0x00
Read i2c bus:8,device:0x2C address:0x70,value:0x00
Read i2c bus:8,device:0x2C address:0x71,value:0x00
Read i2c bus:8,device:0x2C address:0x72,value:0x00
Read i2c bus:8,device:0x2C address:0x73,value:0x07
Read i2c bus:8,device:0x2C address:0x74,value:0x07
Read i2c bus:8,device:0x2C address:0x75,value:0x08
Read i2c bus:8,device:0x2C address:0x76,value:0x00
Read i2c bus:8,device:0x2C address:0x77,value:0x00
Read i2c bus:8,device:0x2C address:0x78,value:0x00
Read i2c bus:8,device:0x2C address:0x79,value:0x00
Read i2c bus:8,device:0x2C address:0x7A,value:0x00
Read i2c bus:8,device:0x2C address:0x7B,value:0x00
Read i2c bus:8,device:0x2C address:0x7C,value:0x02
Read i2c bus:8,device:0x2C address:0x7D,value:0x00
Read i2c bus:8,device:0x2C address:0x7E,value:0x00
Read i2c bus:8,device:0x2C address:0x7F,value:0x00
Read i2c bus:8,device:0x2C address:0x80,value:0x00
Read i2c bus:8,device:0x2C address:0x81,value:0x00
Read i2c bus:8,device:0x2C address:0x82,value:0x00
Read i2c bus:8,device:0x2C address:0x83,value:0x00
Read i2c bus:8,device:0x2C address:0x84,value:0x00
Read i2c bus:8,device:0x2C address:0x85,value:0x00
Read i2c bus:8,device:0x2C address:0x86,value:0x00
Read i2c bus:8,device:0x2C address:0x87,value:0x00
Read i2c bus:8,device:0x2C address:0x88,value:0x00
Read i2c bus:8,device:0x2C address:0x89,value:0x00
Read i2c bus:8,device:0x2C address:0x8A,value:0x00
Read i2c bus:8,device:0x2C address:0x8B,value:0x00
Read i2c bus:8,device:0x2C address:0x8C,value:0x00
Read i2c bus:8,device:0x2C address:0x8D,value:0x00
Read i2c bus:8,device:0x2C address:0x8E,value:0x00
Read i2c bus:8,device:0x2C address:0x8F,value:0x00
Read i2c bus:8,device:0x2C address:0x90,value:0x00
Read i2c bus:8,device:0x2C address:0x91,value:0x00
Read i2c bus:8,device:0x2C address:0x92,value:0x00
Read i2c bus:8,device:0x2C address:0x93,value:0x00
Read i2c bus:8,device:0x2C address:0x94,value:0x00
Read i2c bus:8,device:0x2C address:0x95,value:0x00
Read i2c bus:8,device:0x2C address:0x96,value:0x00
Read i2c bus:8,device:0x2C address:0x97,value:0x00
Read i2c bus:8,device:0x2C address:0x98,value:0x00
Read i2c bus:8,device:0x2C address:0x99,value:0x00
Read i2c bus:8,device:0x2C address:0x9A,value:0x00
Read i2c bus:8,device:0x2C address:0x9B,value:0x00
Read i2c bus:8,device:0x2C address:0x9C,value:0x00
Read i2c bus:8,device:0x2C address:0x9D,value:0x00
Read i2c bus:8,device:0x2C address:0x9E,value:0x00
Read i2c bus:8,device:0x2C address:0x9F,value:0x00
Read i2c bus:8,device:0x2C address:0xA0,value:0x00
Read i2c bus:8,device:0x2C address:0xA1,value:0x00
Read i2c bus:8,device:0x2C address:0xA2,value:0x8C
Read i2c bus:8,device:0x2C address:0xA3,value:0x00
Read i2c bus:8,device:0x2C address:0xA4,value:0x00
Read i2c bus:8,device:0x2C address:0xA5,value:0x00
Read i2c bus:8,device:0x2C address:0xA6,value:0x00
Read i2c bus:8,device:0x2C address:0xA7,value:0x00
Read i2c bus:8,device:0x2C address:0xA8,value:0x00
Read i2c bus:8,device:0x2C address:0xA9,value:0x00
Read i2c bus:8,device:0x2C address:0xAA,value:0x00
Read i2c bus:8,device:0x2C address:0xAB,value:0x00
Read i2c bus:8,device:0x2C address:0xAC,value:0x00
Read i2c bus:8,device:0x2C address:0xAD,value:0x00
Read i2c bus:8,device:0x2C address:0xAE,value:0x00
Read i2c bus:8,device:0x2C address:0xAF,value:0x00
Read i2c bus:8,device:0x2C address:0xB0,value:0x00
Read i2c bus:8,device:0x2C address:0xB1,value:0x00
Read i2c bus:8,device:0x2C address:0xB2,value:0x00
Read i2c bus:8,device:0x2C address:0xB3,value:0x00
Read i2c bus:8,device:0x2C address:0xB4,value:0x00
Read i2c bus:8,device:0x2C address:0xB5,value:0x00
Read i2c bus:8,device:0x2C address:0xB6,value:0x00
Read i2c bus:8,device:0x2C address:0xB7,value:0x00
Read i2c bus:8,device:0x2C address:0xB8,value:0x00
Read i2c bus:8,device:0x2C address:0xB9,value:0x00
Read i2c bus:8,device:0x2C address:0xBA,value:0x00
Read i2c bus:8,device:0x2C address:0xBB,value:0x00
Read i2c bus:8,device:0x2C address:0xBC,value:0x00
Read i2c bus:8,device:0x2C address:0xBD,value:0x00
Read i2c bus:8,device:0x2C address:0xBE,value:0x00
Read i2c bus:8,device:0x2C address:0xBF,value:0x00
Read i2c bus:8,device:0x2C address:0xC0,value:0x00
Read i2c bus:8,device:0x2C address:0xC1,value:0x00
Read i2c bus:8,device:0x2C address:0xC2,value:0x00
Read i2c bus:8,device:0x2C address:0xC3,value:0x00
Read i2c bus:8,device:0x2C address:0xC4,value:0x00
Read i2c bus:8,device:0x2C address:0xC5,value:0x00
Read i2c bus:8,device:0x2C address:0xC6,value:0x00
Read i2c bus:8,device:0x2C address:0xC7,value:0x00
Read i2c bus:8,device:0x2C address:0xC8,value:0xC0
Read i2c bus:8,device:0x2C address:0xC9,value:0x00
Read i2c bus:8,device:0x2C address:0xCA,value:0x00
Read i2c bus:8,device:0x2C address:0xCB,value:0x00
Read i2c bus:8,device:0x2C address:0xCC,value:0x00
Read i2c bus:8,device:0x2C address:0xCD,value:0x00
Read i2c bus:8,device:0x2C address:0xCE,value:0x00
Read i2c bus:8,device:0x2C address:0xCF,value:0x00
Read i2c bus:8,device:0x2C address:0xD0,value:0x00
Read i2c bus:8,device:0x2C address:0xD1,value:0x00
Read i2c bus:8,device:0x2C address:0xD2,value:0x00
Read i2c bus:8,device:0x2C address:0xD3,value:0x00
Read i2c bus:8,device:0x2C address:0xD4,value:0x00
Read i2c bus:8,device:0x2C address:0xD5,value:0x00
Read i2c bus:8,device:0x2C address:0xD6,value:0x00
Read i2c bus:8,device:0x2C address:0xD7,value:0x00
Read i2c bus:8,device:0x2C address:0xD8,value:0x00
Read i2c bus:8,device:0x2C address:0xD9,value:0x00
Read i2c bus:8,device:0x2C address:0xDA,value:0x00
Read i2c bus:8,device:0x2C address:0xDB,value:0x00
Read i2c bus:8,device:0x2C address:0xDC,value:0x00
Read i2c bus:8,device:0x2C address:0xDD,value:0x00
Read i2c bus:8,device:0x2C address:0xDE,value:0x00
Read i2c bus:8,device:0x2C address:0xDF,value:0x00
Read i2c bus:8,device:0x2C address:0xE0,value:0x00
Read i2c bus:8,device:0x2C address:0xE1,value:0x00
Read i2c bus:8,device:0x2C address:0xE2,value:0x00
Read i2c bus:8,device:0x2C address:0xE3,value:0x00
Read i2c bus:8,device:0x2C address:0xE4,value:0x00
Read i2c bus:8,device:0x2C address:0xE5,value:0x00
Read i2c bus:8,device:0x2C address:0xE6,value:0x00
Read i2c bus:8,device:0x2C address:0xE7,value:0x00
Read i2c bus:8,device:0x2C address:0xE8,value:0x00
Read i2c bus:8,device:0x2C address:0xE9,value:0x00
Read i2c bus:8,device:0x2C address:0xEA,value:0x00
Read i2c bus:8,device:0x2C address:0xEB,value:0x00
Read i2c bus:8,device:0x2C address:0xEC,value:0x00
Read i2c bus:8,device:0x2C address:0xED,value:0x00
Read i2c bus:8,device:0x2C address:0xEE,value:0x00
Read i2c bus:8,device:0x2C address:0xEF,value:0x00
Read i2c bus:8,device:0x2C address:0xF0,value:0x5F
Read i2c bus:8,device:0x2C address:0xF1,value:0x55
Read i2c bus:8,device:0x2C address:0xF2,value:0x42
Read i2c bus:8,device:0x2C address:0xF3,value:0x39
Read i2c bus:8,device:0x2C address:0xF4,value:0x34
Read i2c bus:8,device:0x2C address:0xF5,value:0x38
Read i2c bus:8,device:0x2C address:0xF6,value:0x00
Read i2c bus:8,device:0x2C address:0xF7,value:0x00
Read i2c bus:8,device:0x2C address:0xF8,value:0x00
Read i2c bus:8,device:0x2C address:0xF9,value:0x00
Read i2c bus:8,device:0x2C address:0xFA,value:0x00
Read i2c bus:8,device:0x2C address:0xFB,value:0x00
Read i2c bus:8,device:0x2C address:0xFC,value:0x00
Read i2c bus:8,device:0x2C address:0xFD,value:0x00
Read i2c bus:8,device:0x2C address:0xFE,value:0x00
/usr/bin/config_ds9478_S106.sh[579]: cannot create ds947-948.txt: Read-only file system
