Hi team,
Customer want to use TPS25750 EVM program the EEPROM on their board using GUI. Their configure is "AlwaysEnableSink" mode. Could they remove the EEPROM on our board, and connect the I2C bus to their board point 1 SCL and point 2 SDA, and use GUI to program directly? Is there any timing sequence that need to be noted? Hope you could share some comments.
Will
