Part Number: SN65HVD1473
Hi there,
I'm using the SN65HVD1473 transceiver in RS-422 mode. As the data rate is over 200 Kbps we need a 120ohm terminaison resistor. What reference do you advise to use? Which package?
In fact, the EIA-422 indicates a maximum differential voltage equal to 12V, does it mean the 120 ohm resistor has to support 1,2 Watt?
Best regards.
Megane TREMBLIER
