Part Number: TCAN1046V-Q1
Hi Team,
If the TCAN1046V-Q1 is being used as CAN for UART, then a user needs to be aware of dominant timeout. A large number of consecutive dominant bits or very low data rates can cause the dominant timeout to trigger for the transmitter and/or receiver, forcing the output to recessive.
Is this the recommended minimum baud rate for uart to prevent the dominant timeout 9.2kbps?
Also, would the TX UART need to constantly send some sort of keep alive data to the transceiver at a minimum of 9.2 kbps to prevent the CAN from going into DTO?
Thank you,
Jared
