Part Number: TLIN1029-Q1
Hi team,
Does TLIN1029 have specification for input transition rise or fall rate ?
Are there any concern if slow signal is coming for input ?
Thank you and best regards,
Michiaki
Hi team,
Michiaki
Michiaki,
There isn't a specification for rise or fall time on the TLIN1029 for it to translate the signal to the LIN bus, but there is a limit for the overall data rate of the signal input on the TXD pin. If the rise and/or fall time is so long that it will be a significant portion of the bit width, this may be a problem in the dominant case for triggering dominant timeout (when the TXD/LIN bus is in the dominant state for too long), but otherwise there should be no issues.
Can you give more timing parameters on the slow signal?
Eric Hackett
