Part Number: TS3DV642
Hi Sirs,
May I know the TS3DV642 can or not support the resolution up to 7680*4320@60Hz (8.1Gbps) ?
Hi Sirs,
TD3DV642 supports DP1.4 switching which is 8.1G. You may also need to consider a DP redriver(DP141/DP142) at the output for signal integrity compensation.
David
