Part Number: TPS25810
Dear Team,
I would like to know the current limit behavior when CC short to GND.
Will it clamp the current or turn off the power switch? How it work?
Thank you.
Jim
Hi Jim,
The TPS25810 only applies VCONN on CC when it detects that a Ra is presented within the cable.
You can see the current limit for the CC pins when VCONN is applied. If this current limit is exceeded, then the TPS25810 will remove VCONN and open up that power path.
