Part Number: DS90C032QML
Hello Team,
Can you share with us the max-rated output current of this part (max current it can output)? It is not listed in the datasheet.
Regard,
Renan
Hello Team,
Regard,
Renan
Greeting Renan,
This parameter is indirectly noted in the data sheet electrical characteristic table. Please note VOH and VOL parameters with IOH and IOL respectively. Every part in production is tested and meets these min and max voltages. As long as IOH and IOL numbers in the table are used then part will provide VOH and VOL numbers mentioned. Therefor we need to be within the range of IOH and IOL calues.
Regards ,, Nasser
