Part Number: SN65DSI84-Q1
Hi Experts,
Can someone explain on the queries given below:
1. The data sheet section 8.3.1 says that DSI PHY Clock needs to be run in specific mode (HS free running/continuous) ? Can this be explained ? Is it High speed configuration of DPHY in SoC or any other specific mode ?
2. We dont have the REFCLK sourced externally, We are relying on DSI DPHY clock. Datasheet says that test pattern mode will ignore the DSI inputs. Does test pattern mode uses the DSI clock in this case ?
Arun Gangadharan
