Part Number: DP83849I
We would like to do 100BASE-TX Compliance TEST using a board (DUT) on which the DP83849I is mounted.
To do the TEST, the scrambled idle pattern should be outputted from DP83849I.
Could you give us how to output the scrambled idle pattern from DP83849I?
Is it possible by setting registers of DP83849I?
Thank you.
