Part Number: DS90UB948-Q1
Hello Team,
My customer is using our 948 in a designing project, here are two questions need your support.
1. In the eye diagram, it can be found that the rising edge and falling edge of the signal are longer than 1.2ns. I want to know if the LVDS output can increase the LVDS ICC current value? If possible, please advise how to set and use it.
2. The ESD test found a white noise flashed past the screen. It is suspected that LVDS signal transmission lost a few bit data when doing ESD test. Is there any good way to eliminate the white noise? Could adaptive equalizer solve this problem? If possible, please guide how to set and use it.
Thank you a lot!
BR,
Hans
