Part Number: DS90UB960-Q1
we are using DS90UB960 in one of our design, we will connect DS90UB913A and DS90UB953 , so i have attached POC schematics to support both serializes, please check whether it can support both ?
Narendar
Narendar
Hello Narendar,
your PoC schematic looks good to me, you just need to change the AC-Coupling caps to 100nF instead of 33nF, and 49nF instead of 15nF.
At the end and most important is the measurement result which needs to fulfill our transmission channel specifications.
Hello Hamzeh,
at present we adapt our system consisting of camera with 953 SER and ECU with 960 DES to PoC interface (formerly made as STP). Schema from camera side see attached.
We designed the network inspired by TI DS90UB960 data sheet (Figure 8-2. Typical PoC Network for a "4G" FPD-Link III), but our transmission mode between 953 and 960 depends on imager type mounted (1.3Mp -> RAW12HF, 2.1Mp -> CSI-2 non-sync).
There are still problems at link and transmission errors. We have already tried to vary C5/C6 to 100nF/47nF.
How can we check whether we fulfill the transmission channel specifications?
Torsten
Hello Torsten,
we do have Test Instructions document but I can send that only via email and only with a valid NDA.
Hello Hamzeh,
that sounds good.
My email is Torsten.Kilias@te.com.
I am sure, that my company has a valid NDA (I could care for the information).
Torsten
Hello Torsten,
We will follow up early next week Mon/Tues
Casey
Hello Torsten,
Can you please send me a private message through E2E with your company information?
Casey
