Part Number: DP83822I
Hi team
When using Dp83822i, customer got below eye diagram, and fail the eye diagram test, the blue area is above the yellow line.
1, Is there any config either hardwar or software that could adjust the output capability to wider the output to ensure cover the blue area?
2. What is the purpose of the RBIAS pull-down resistor in datasheet, i am not sure whether this pin can be adjusted to adjust the eye diagram?
Best Regards
