Part Number: TFP401
Dears,
We are using TFP401. It is found it has CLK and HSYNC output. But does not have VSYNC output.
Could you help advise how to check this issue?
Thanks a lot!
-Rocky
Part Number: TFP401
Dears,
Thanks a lot!
-Rocky
Is this the same issue which they are not seeing both HSYNC and VSYNC?
1. Can you please provide the schematic for review?
2. What is the resolution you are trying to use? Does the issue happen across multiple resolutions?
3. Does the issue happen across multiple TFP401A?
4. Does the HDMI video contain audio? The TFP401A does not support embedded audio.
David
we can capture VSYNC but not have HSYNC signal.
1、We can do it tomorrow.
2、We use 1080p@60Hz, we use only one picture to display.
3、We use single chip;
4、Yes,Our source is HDMI2.0 with video embedded audio.So,how we can do that?
Can you disable audio on the source side and see if you can see the HSYNC?
Are you seeing the issue across multiple TFP401A?
David
