Part Number: TPS65987DDK
Hello. What firmware file should I use for the TPS65987DDK? The Application Configuration Utility version 6.1.2 does not list that part specifically.
Thanks.
Thanks.
Hi David,
Could you please add me and provide your email and I will connect with you offline.
Thank you,
Hari
Hi David,
I have sent it again on the email that you provided earlier on this thread, is that the correct one?
Thank you,
Hari
Armand: This part is recommended only for Thunderbolt applications. However, the firmware that comes with the Application Customization Utility version 6.1.2 can be used to program and configure this part. Select the TPS65987DDH to start a new project. Note that the 987DDK will identify itself as a 988 which has 2 ports. Make sure to disable any references to port 2.
Ok... thanks!
One question, in validating the 987DDK for warranty reasons, will TI allow using 988D?
Hi please post a new question with specifics about your design and application.
Thank you,
Hari
