Part Number: THVD1451
Dear Team,
My customer is thinking to use the THVD1451 Full-Duplex None-Enables RS-485 transceiver in their system. Since the THVD1451 does not have Enables, Bus topology will be Multi-drop, right?
One Master and multi Slaves.
The Bus line from the Master (Driver) to multi Salves (Receiver);
It is OK for multi Slaves to be powered on, because multi Slaves are receivers.
The Bus line from multi Slaves (Driver) to the Master (Receiver);
When one Slave drives the Bus to transmit the data to the Master, the other Slaves should be powered off not to drive the bus, right?
How to control the timing of power-on of Slaves?
I look forward to your reply.
Thank you.
Koshi Ninomiya
