Part Number: TPS65983B
Dear all
when we send the device to GRL to test . (thunderbolt3 to 2 ch dp).
We get the next fail
USB POWER Delivery tests |
GRL C2 v1.5.93.0 |
Communication Engine Test |
Fail |
1. TDA.2.2.5 BMC PROT DISCOV |
PD 3.0 Test |
Fail |
1. TD.PD.SNK3.E11 Receiving chunked extended message |
the attachment is xmil and *.prj file
pls help me fix it thansk !
<?xml version="1.0" encoding="utf-8"?>
<vif:VIF xmlns:opt="http://usb.org/VendorInfoFileOptionalContent.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:vif="http://usb.org/VendorInfoFile.xsd">
<vif:VIF_Specification>3.14</vif:VIF_Specification>
<vif:VIF_App>
<vif:Vendor>USB-IF</vif:Vendor>
<vif:Name>VIF Editor</vif:Name>
<vif:Version>3.2.0.1</vif:Version>
</vif:VIF_App>
<vif:Vendor_Name>ACASIS</vif:Vendor_Name>
<vif:Model_Part_Number>AC-TB2D</vif:Model_Part_Number>
<vif:Product_Revision>0x1</vif:Product_Revision>
<vif:TID>NA</vif:TID>
<vif:VIF_Product_Type value="0">Port Product</vif:VIF_Product_Type>
<vif:Certification_Type value="0">End Product</vif:Certification_Type>
<vif:Product />
<vif:Component>
<vif:Port_Label>C</vif:Port_Label>
<vif:Connector_Type value="2">Type-C®</vif:Connector_Type>
<vif:USB4_Supported value="false" />
<vif:USB_PD_Support value="true" />
<vif:PD_Port_Type value="0">Consumer Only</vif:PD_Port_Type>
<vif:Type_C_State_Machine value="1">SNK</vif:Type_C_State_Machine>
<vif:Port_Battery_Powered value="false" />
<vif:BC_1_2_Support value="0">None</vif:BC_1_2_Support>
<vif:PD_Spec_Revision_Major value="3" />
<vif:PD_Spec_Revision_Minor value="0" />
<vif:PD_Spec_Version_Major value="0" />
<vif:PD_Spec_Version_Minor value="0" />
<vif:PD_Specification_Revision value="2">Revision 3</vif:PD_Specification_Revision>
<vif:SOP_Capable value="true" />
<vif:SOP_P_Capable value="true" />
<vif:SOP_PP_Capable value="false" />
<vif:SOP_P_Debug_Capable value="false" />
<vif:SOP_PP_Debug_Capable value="false" />
<vif:Manufacturer_Info_Supported_Port value="true" />
<vif:Manufacturer_Info_VID_Port value="32903">8087</vif:Manufacturer_Info_VID_Port>
<vif:Manufacturer_Info_PID_Port value="0">0000</vif:Manufacturer_Info_PID_Port>
<vif:Unconstrained_Power value="false" />
<vif:ID_Header_Connector_Type_SOP value="3">USB Type-C® Plug</vif:ID_Header_Connector_Type_SOP>
<vif:Chunking_Implemented_SOP value="true" />
<vif:Unchunked_Extended_Messages_Supported value="true" />
<vif:Security_Msgs_Supported_SOP value="false" />
<vif:Num_Fixed_Batteries value="0" />
<vif:Num_Swappable_Battery_Slots value="0" />
<vif:USB_Comms_Capable value="true" />
<vif:DR_Swap_To_DFP_Supported value="false" />
<vif:DR_Swap_To_UFP_Supported value="false" />
<vif:VCONN_Swap_To_On_Supported value="false" />
<vif:VCONN_Swap_To_Off_Supported value="false" />
<vif:Responds_To_Discov_SOP_UFP value="true" />
<vif:Responds_To_Discov_SOP_DFP value="false" />
<vif:Attempts_Discov_SOP value="false" />
<vif:Type_C_Can_Act_As_Host value="false" />
<vif:Type_C_Can_Act_As_Device value="true" />
<vif:Type_C_Supports_Audio_Accessory value="false" />
<vif:Type_C_Supports_VCONN_Powered_Accessory value="false" />
<vif:Type_C_Is_VCONN_Powered_Accessory value="false" />
<vif:Type_C_Is_Debug_Target_SNK value="false" />
<vif:Captive_Cable value="true" />
<vif:Captive_Cable_Is_eMarked value="false" />
<vif:Type_C_Port_On_Hub value="true" />
<vif:Type_C_Power_Source value="0">Externally Powered</vif:Type_C_Power_Source>
<vif:Type_C_Sources_VCONN value="false" />
<vif:Type_C_Is_Alt_Mode_Controller value="false" />
<vif:Type_C_Is_Alt_Mode_Adapter value="false" />
<vif:Device_Supports_USB_Data value="true" />
<vif:Device_Speed value="3">USB 3.2 Gen 1x2</vif:Device_Speed>
<vif:Device_Max_USB2_Speed value="2">High Speed</vif:Device_Max_USB2_Speed>
<vif:Device_Contains_Captive_Retimer value="false" />
<vif:Device_Truncates_DP_For_tDHPResponse value="false" />
<vif:PD_Power_As_Sink value="15000">15000 mW</vif:PD_Power_As_Sink>
<vif:No_USB_Suspend_May_Be_Set value="false" />
<vif:GiveBack_May_Be_Set value="false" />
<vif:Higher_Capability_Set value="false" />
<vif:FR_Swap_Reqd_Type_C_Current_As_Initial_Source value="0">FR_Swap not supported</vif:FR_Swap_Reqd_Type_C_Current_As_Initial_Source>
<vif:Num_Snk_PDOs value="1" />
<vif:SnkPdoList>
<vif:SnkPDO>
<vif:Snk_PDO_Supply_Type value="0">Fixed</vif:Snk_PDO_Supply_Type>
<vif:Snk_PDO_Voltage value="100">5000 mV</vif:Snk_PDO_Voltage>
<vif:Snk_PDO_Op_Current value="300">3000 mA</vif:Snk_PDO_Op_Current>
</vif:SnkPDO>
</vif:SnkPdoList>
<vif:XID_SOP value="0" />
<vif:Data_Capable_As_USB_Host_SOP value="false" />
<vif:Data_Capable_As_USB_Device_SOP value="true" />
<vif:Product_Type_UFP_SOP value="2">PDUSB Peripheral</vif:Product_Type_UFP_SOP>
<vif:Product_Type_DFP_SOP value="0">Undefined</vif:Product_Type_DFP_SOP>
<vif:Modal_Operation_Supported_SOP value="true" />
<vif:USB_VID_SOP value="32903">8087</vif:USB_VID_SOP>
<vif:PID_SOP value="0">0000</vif:PID_SOP>
<vif:bcdDevice_SOP value="1639">0667</vif:bcdDevice_SOP>
<vif:SVID_Fixed_SOP value="false" />
<vif:Num_SVIDs_Min_SOP value="1" />
<vif:Num_SVIDs_Max_SOP value="1" />
<vif:SOPSVIDList>
<vif:SOPSVID>
<vif:SVID_SOP value="32903">8087</vif:SVID_SOP>
<vif:SVID_Modes_Fixed_SOP value="true" />
<vif:SVID_Num_Modes_Min_SOP value="1" />
<vif:SVID_Num_Modes_Max_SOP value="1" />
<vif:SOPSVIDModeList>
<vif:SOPSVIDMode>
<vif:SVID_Mode_Enter_SOP value="true" />
<vif:SVID_Mode_Recog_Value_SOP value="0">00000000</vif:SVID_Mode_Recog_Value_SOP>
</vif:SOPSVIDMode>
</vif:SOPSVIDModeList>
</vif:SOPSVID>
</vif:SOPSVIDList>
</vif:Component>
</vif:VIF>
