Part Number: PCA9306
Other Parts Discussed in Thread: TCA9509, TCA39306
Dear team
there are some questions when my customer use PCA9306. in case we are discussing same application, using 1.8V to 3.3V open drain as an example.
I have learn from LSF training video, and understand why we use pull-up res 200K in EN and vref2 pin. but still confused by these questions like below
- PCA9306 must have pull-up resistor in EN pin when open drain application, why other sockets like pull up resistor for TCA9509 EN pin is not must.
TCA39306 is the P2P solution with Pca9306, which has better performance, wider voltage range, and higher speed rate. there are no limit for EN pull-up resistor in TCA39306, why? could you help to explain in schematic view?
BR
Chi
