Part Number: DP83848J
Customer would like to confirm how to deal with pin 34 (RX_ER/MDIX_EN) if using DP83848 half-duplex mode. Could it be left float? Thank you.
If the MAC the customer is using needs it then it needs to be connected. Also they should be okay with the default strap setting for this pin if left floating.
Kind Regards,
Joe
All information in this correspondence and in any related correspondence is provided “as is” and “with all faults”, and is subject to TI’s Important Notice (www.ti.com/.../important-notice.shtml)
Joe,
Thank you. You mean it is required to use the default setting of MDIX ENABLE for pin34 if left floating, right?
You are correct, The default setting of this pin will have to work for their design.
Kind Regards,
Joe
