Part Number: TCAN1043A-Q1
Other Parts Discussed in Thread: TCAN1043
Hi Team,
Customer would use TCAN1043GDMTRQ1 !
But I would like to promote TCAN1043A-Q1 to customer, Can you recommend the part number to me? THX
Hi Team,
Hi Team,
I think PTCAN1043ADMTRQ1 would be a good replacement to TCAN1043GDMTRQ1!
Is there any side effect that needs attention? THX
Hi Kygo,
Yes, this will be a good recommendation. The TCAN1043A describes that the device supports up to 8Mbps. I will send you a migration guide offline.
Eric Schott
Hi Eric,
Based on the data-sheet , the TCAN1043A operation range of Vsup is 4.5 to 28V.
Please confirm the specification, Normally, customer need Vsup should be >36V.
And TCAN1043 operation range of Vsup is -0.3 to 58V. THX
[ES]: Removed old datasheet images.
Hi Kygo,
Please see the most recent datasheet version on the sharepoint. The July revision shows a supported operational Vsup range up to 40V.
Eric Schott
