TLK2711-SP: dimension of HFG (S-CQFP-F68) package (TLK2711-SP 5962-0522101VXC)
Part Number: TLK2711-SP
Hello Team,
Could you please let me know the minimum and nominal dimensions for A1 and A2 of 5962-0522101VXC? (see SMD_5962-0522101VXC(A1_A2).pdf)?
As you can see, minimum values for A1 and A2 are not defined in the datasheet.
We need this information to determine our lead forming spec.
The PDF above is from the current version of the standard microcircuit drawing.
https://landandmaritimeapps.dla.mil/programs/smcr/detail.aspx?source=TI&spn=5962-0522101VXC&vspn=TLK2711-SP
It appears that you have revised the spec, and the following should be the latest specification.
https://www.ti.com/lit/pdf/mcqf014f?_ticdt=MTYzMDY5MTc3MnwwMTc4YjkxZjUwNzcwMDEyNjAxNGY2YTMyMTE1MDEwNzMwMDIxMDZiMDBiZDB8R0ExLjIuMjAyODA5NDY1Ny4xNjE4NDMyNjUy
Could you please also let me know if you plan to update the standard microcircuit drawing?
