Part Number: DS90UB921-Q1
hi Teams:
Can ds90ub921-q1 support 960 * 1280 resolution?
The DS90UB921-Q1 can support a PCLK range of 5-96MHz when in STP mode, or 15-96MHz when in Coax mode. The 960*1280 resolution likely falls within this range, although that depends on the size of the blanking that is used. To determine the PCLK you will be using, use the following equation:
PCLK = (TotalHorizontalPixels*TotalVerticalLines)*RefreshRate
Ben
