Part Number: TPD3S044
Other Parts Discussed in Thread: TPD3S014,
We just started production of a series machines for our customer where we use the TPD3D044 as USB protection device (including current limiter). We have 6 USB ports per machine so each machine (PCB) uses 6 of these devices. At this moment we are starting a series of 50 so we need 300 of these parts. However the problem is that the lead time is extreme long and we can not find any supplier where these devices are on stock. The TPD3S014 could in fact be use as an alternative but in that case the current limit is lower and our customer asked us for USB ports that can handle more power at the USB supply output. Do you have a suggestion because we can not find an alternative (pin compatible) for this and our PCB supplier is waiting for a solution. And what is the reason for this extreme long lead time for this product? We are aware of the problems on the chip market but the lead time for the TPD3S044 seems very long at this moment.
Chris van der Aar
Sr. Hardware Engineer
NTS Systems Development
Eindhoven , The Netherlands
