Part Number: SN65HVD266
Other Parts Discussed in Thread: TCAN1051
Please provide a detailed review . And also suggest the method to calculate the values of capacitors choke at the filter section of the IC.
Hi Aswin,
May I recommend a newer 8-pin Silent mode CAN transceiver such as TCAN1051 or TCAN1057A? If there is a particular reason why SN65VHD266 was chosen, there is no problem using this device as shown.
This schematic looks good. I don't have any changes to recommend. See my comments below.
Let me know if you have any specific questions or concerns.
Eric Schott
Hi Aswin,
I'm correcting the termination value typo above. Total resistance from slit termination should be 120-ohms normally, meaning two 60-ohm resistors for split termination.
Eric Schott
