Part Number: DP83867IR
Hi
I found the magnetic isolation characteristic in the datasheet. Page.117
The open circuit inductance is from 320uH to 350uH.
so, What happens if I use an inductance of less than 320uH?
Thank you.
Hi
Thank you.
You may see some impact in the MDI signal as the magnetic isolation impedance is no longer within the recommended range. You may try running the IEEE PMA compliance tests to confirm the effect of using a different impedance.
Thank you,
Nikhil
All information in this correspondence and in any related correspondence is provided “as is” and “with all faults”, and it is subject to TI’s Important Notice (http://www.ti.com/corp/docs/legal/important-notice.shtml).
