Part Number: DP83848T
Has anyone the DP83848T PHY running with the dp83848.c driver?
The driver registers an Interrupt and reads/writes to the reserved interrupt registers... (0x11, 0x12/MICR, MISR). So that can not work at all, since MICR, MISR are not present on the T version
I've DP83848T PHY running with the "Generic PHY" driver in linux 5.10.
@ TI, you might want to double check that and update the compatibility list.... (www.ti.com/.../ETHERNET-SW)
