Part Number: TCA8418
Hello, I am attempting to write values into register 0x04 KEY_EVENT_A register to simulate physical keypresses for lab automation validation. Per the datasheet I should be able to read/write to any register. However, when I attempt to write to registers 0x02 through 0x04 nothing is stored in these registers, only zeros.
Is there a method or process to write these registers? Is there another method which could be used to trigger the Interrupt and send the desired values to the controller from this IC?
thank you.
