Part Number: TPS65988EVM
Other Parts Discussed in Thread: TPS65987D
I want to know the I2C register of highlighted field. How I can read the vendor data from I2C register?
Hi Niket,
If you are using the EVM, you can go into debug mode to see the register values. However, if you are asking about for your own design, if you have a Host/EC connected to the PD controller, it will need to be read the register with the I2C address of the PD controller. Is this what your are asking for? Could you elaborate some more if I am not understanding?
Thank you,
Hari
In our design, we connected the micro-controller with the PD controller over I2C. I want to read the highlighted field using the micro-controller. I am able to read the PD controller registers over I2C. But I don't know which register I have to read to get the highlighted field.
Hi Niket,
I see, please refer to the TPS65987D Technical Reference Manual for this information: https://www.ti.com/lit/ug/slvubh2b/slvubh2b.pdf
Thank you,
Hari
I have already gone through it but I did not find a suitable register. Can you help me with this?
Hi Niket,
The particular field that you have highlighted will be found on register 0x4a:
Thank you,
Hari
