Part Number: TPD1E05U06-Q1
Can I use the TPD1E05U06-Q1 for ESD protection for the PS/2 Data, clock and +5V outputs ?
Hi Shmuel,
Yes. TPD1E05U06-Q1 will provide excellent protection for that application.
Matt Smith
Dear Mat,
For the +5V supply I will be using also a Current Limited Switch or Resettable Fuse etc. in series. Where should the TPD1E05U06-Q1 be placed between the switch\fuse and the output pin OR before the switch\fuse (i.e. TPD1E05U06-Q1 then Fuse then +5V output pin) ?
Best Regards
Shmuel
Hi Shmuel,
The general rule of thumb is to place the ESD diode as close to the ESD source (i.e. the PS2 connector) as possible to minimize inductance. Ideally, it should be 1.) connector, 2.) TPD1E05U06-Q1, 3.) switch/fuse, 4.) all other downstream circuitry.
Please refer to page 3 of this guide for details: https://www.ti.com/lit/an/slvaex9/slvaex9.pdf?ts=1633460574017&ref_url=https%253A%252F%252Fwww.ti.com%252Finterface%252Fcircuit-protection%252Fesd-surge-protection-ics%252Ftechnical-documents.html
Matt Smith
