Part Number: PCA9306-Q1
I am using the PCA9306-Q1 as an I2C switch using the switch enable control diagram found in the datasheet.
I wanted to know will there be any issues if I were to set both Vref1 and Vref2 to 3.3V. See the diagram below for ref.
I also noticed within different sections of the datasheet Vref2 is usually greater than Vref1. In my application, is this required? If not, when is it required to have Vref2 > Vref1?
Thank you,
Eric
