Part Number: DP83TC812S-Q1
Hi Team,
For the RX interface, there are IBIS models available for a normal mode and a slow mode, for each of the I/O voltages. I was expecting different models for various series resistor values, but there is just the normal mode and the slow mode.
One of the datasheet versions said the default resistance is 58 ohms, but the value can be set from 42 to 99 ohms through an impedance control register.
Could you clarify how does the part actually work? Normal / slow output strength or 42 to 99 ohms resistance?
David
