Other Parts Discussed in Thread: TS3L110
Hi Team,
Can you please check and advise with following request?
We are considering a where we can receive both RS-422 and Ethernet signals from the same connector.
In this context, we need an IC that is compatible with the physical layer of both protocols that can switch RS-422 and Ethernet signals over itself and transmit them to the connector.
Is there an IC suitable for our needs among TI products?
Alternatively, if such a special purpose IC is not available, can you suggest an analog mux suitable for signal levels at the Ethernet and RS-422 physical layers?
Thanks in advance
Best Regards
Furkan Sefiloglu
