We are using DP83822I PHY in RMII master mode in our design.
We have required DP83822I PHY Output 50-MHz Reference Clock Accuracy values and Clock Rise/Fall Timing values for design calculations.
Please convey the same.
Rohidas
Rohidas
Hello Rohidas,
50 MHz clock will have the same accuracy as the 25MHz reference clock. If 25MHz is +/50ppm then 50MHz will also be +/50ppm.
Rise/fall time depends upon the load cap. Approximate number is < 1ns for 5pF of cap.
Vikram
Hello Sir,
Thanks for feedback.
Is there any reference document of PHY in which rise/fall time is mentioned
Rohidas
Hello Rohidas,
As mentioned, rise/fall time depends upon the load on the pin. If accurate rise/fall times ar required then you may simulate the IBIS model with the required load.
https://www.ti.com/lit/zip/snlm205
Vikram
Hello TI Team,
I am using same PHY IC and RMII Mode 50MHz Reference clock.
In my design MCU MAC have input pin load capacitance is 8pF. So, what will be the rise/fall time?
Thanks and Regards,
Ramdas
Hello Ramdas,
It will be better/more accurate to simulate your board + load cap with ibis model. https://www.ti.com/lit/zip/snlm205
Vikram
Hello Vikram San,
We don't have facility to simulate ibis model.
Can you please suggest rise/fall time with 8pF load capacitance?
Hello Ramdas,
Without any extracted load of traces I can approximate it to be ~2ns. But we can't guarantee and if critical do refer to board level simulations.
Vikram
