Part Number: LMH0344
Regarding the BYPASS input to LMH0344, the datasheet shows "This pin does not have an internal pulldown. If the bypass function is not used, this pin requires
an external pulldown resistor to disable bypass." The datasheet does not indicate if this pin has an internal pullup. I'd like to enable the BYPASS function. Can I leave this pin floating or do I need to add a pullup?
Hal Steger
