Part Number: TCA9511A
Other Parts Discussed in Thread: PCA9306
If I power the TCA9511A off a 3.3V rail, can I connect it to a 5V bus? The datasheet suggests tying the bus lines to VCC, but the maximum ratings for those pins is not dependent on VCC. Also if I'm not using the part for hot swapping, is there any difference between the I2C IN/OUT sides?
Thank you in advance.
Maynard
