Part Number: DP83822H
Other Parts Discussed in Thread: DP83822I
Dear expert:
The client on my side has some trouble when debugging phy device DP83822. The software is initialized successfully, the computer shows that the network cable is connected, but unable to mount successfully.
The main platform they use is NXP’s I.MX RT1064. And they formerly used DP83848 and now replaced it by DP83822.The attached file is the schematic circuit customer designed of DP83822 referring to our reference design.
Could you please kindly give some advice on:
- Is the hardware circuit configuration correct?
- Is there any difference between DP83848 and DP83822 in the software configuration?
This would be great help, thank you!
