I have some question.
1. What does it mean "Front-Port Ingress (Module-to-Host)"??
ex. SFP+ ==> Retimer ==> CPU ???
2. We are going to use as Ethernet(10.3125G/1.25G) mode.
And we will use two retimer(DS125DF410). One of the retimer will use for Tx line(Engress), other retimer will use for Rx line(ingress).
Also we will set Register Programming via SMBus.
1) could you provide that as Front-Port Ingress Configuration Sequence(SNLA323, p6)???
2) could you provide that as Front-Port Egress Configuration Sequence(SNLA323, p6~7)???
