Part Number: TMDS171RGZEVM
Other Parts Discussed in Thread: TMDS171
Hi
This case was closed .
I Think I have the same problem . ( my video is out of sync when I hot plug the DVI connector )
What was the solution ?
Shlomi
Hi
Shlomi
Shlomi
Can you please provide the link to the closed case?
What video resolution are you trying to support? And can you measure the TMDS171 output clock frequency? Does the output clock frequency match with the video resolution?
David
Hi David
the case name "
I don't have any access to the signals.
low resolution (XGA)
It is not happen all the time.
If the picture is good it will stay good .
When the picture is out of sync ( very noisy picture or white screen mostly) then I toggle the PD_EN by I2C and the problem fixed.
Re-plugging the cable also fix the problem.
The problem appears at power up or by plugin the cable slowly with and angle .
My quotation if their is any register that can indicate if their is a problem so I can reset the part .
Can you use the EyeScan SW to dump out the TMDS171 registers and compare between the working and the non-working case? The SW can be download at this link, https://www.ti.com/product/TMDS171#design-development.
David
